Rust spots..
Old Jan 22, 2004 | 08:43 PM
TeckniX's Avatar
Rust spots..
I have some horrible rust spots on my silvia. They are where the frame touches the pillow mounts?? (ok I can't remember the name where the suspension bolts-up). Anyway i was wondering if I could just grind the rust, and do nothing.. or maybe slightly tig weld it? I dunno.. I guess I'm just wondering if anyone else had this problem, and how they solved it.
Here's the ugly one ->
thanks!
Old Jan 23, 2004 | 12:44 AM
matt180sx's Avatar
i found this stuff called rust mort, its a liquid you put on rust spots and it counteracts the oxidation that caused it in the first place. the stuff works great and it can be found at most stores that sell autobody supplies. i believe its a 3m product but not sure about that it might be another brand as well.
Old Jan 23, 2004 | 08:13 AM
TeckniX's Avatar
So it will reverse the effect of the rust and turn this into shiny metal again? or it will just stop the rusting process?
Old Jan 23, 2004 | 08:15 AM
TeckniX's Avatar
Btw the funny thing is mort in french means death.. so the product is called: Death to rust pretty much .. I know.. I know.. useless info
Old Jan 26, 2004 | 05:59 AM
Peas's Avatar
Go to walmart or any automotive store like auto zone and ask for rust preventatives and rust inhibitors. They'll direct you to the right isle where you can pick out sprays for rust. They WONT return your things back into SHINY metal, because its not exactly a miracle worker, but it will however STOP the rust from spreading. Some sprays do turn into hard black metal which u can sand and paint over. Which is good! I suggest you fix this as quick as possible, before anymore damage is inflicted to your left shocks. Good luck!
Old Jan 26, 2004 | 06:02 AM
Peas's Avatar
by the way, i suggest you replace the nuts on the shocks, that thing looks rusted to the core. DO NOT spray the stop-rust stuff on it. Just replace them.
kable
Nov 19, 2007 12:02 AM
sav180
Northeast
Sep 24, 2006 04:10 PM
NismoStoner
Mar 3, 2006 11:53 AM
djw46810
Oct 29, 2005 03:01 AM
sav180
Northeast
Jul 16, 2005 10:13 PM
