Upgrading Light Bulbs
When upgrading light bulbs they say H4, H1, etc.
The H# means what kind of housing it is correct?
On a 95 240sx the H4 are the low beams, H1 is the high beams, right?
What housing is the turn signal?
Then on my 89 hatch 240 the flip up light housings are H4 right?
H1, H4, etc. is the bulb not the housing. Housings would be for sealed beam headlights like the S13, which to answer your question is a 6054 housing. Turn signals are usually 1156 or 1157 bulbs depending on if you need single or dual filament. S13 needs a 1157, I dunno bout the S14 though. Just take out the bulb and see what it says.
hmm.. i have a 95.. the high/lows are H1.. the one that is onlee highs are 9005s or 9006s.. i ferget.. the turn signals are the big single filament ones.. i dont really pay attention to the numbers.. if it fits.. i'll take em! haha
and the corners/sidemarkers are those itty-bitty wege ones.. same size as your dash lights if you wanna change em.. check out my pics on my ride in the registry area up top ^ and how i changed the headlight setup and dash
and the corners/sidemarkers are those itty-bitty wege ones.. same size as your dash lights if you wanna change em.. check out my pics on my ride in the registry area up top ^ and how i changed the headlight setup and dash Thread
DCTperformance
Mar 19, 2003 01:56 PM
less colors in the back.. and the reverse lights.. its a yellow bulb now.. not amber..
