What's up with my car!?!?!
Old Feb 13, 2003 | 09:04 PM
Jenn240's Avatar
Angry What's up with my car!?!?!
Okay, I'm having a hard time figuring out what's up with my car. When I get up to about 55 + mph, the car has a really bad shimmy in the front end. I have a hard time holding the wheel straight. I looked around a little bit. I found that all my tires are the same EXCEPT the front passenger side,it is a different tread then the others. I ran my hand over the driver's side front tire and it's cupped- in other words it's not smooth like the unmatched tire is. I think it might be a strut. And, whatever it is, it's getting worse. Before it would start this at 65-70mph, now it starts at 55mph. If any of you guys might know what it is, please let me know. Thank you all so much!!!!!
Old Feb 14, 2003 | 06:40 AM
EvilCerealBoX's Avatar
could be your power steering chip is messed up... its like that on my mom's suburban... but i think it was more of a ABS problem when i brake it shakes..
Old Feb 14, 2003 | 07:37 AM
3rdchild's Avatar
my 95 le kinda does the same thing too... driving on the highway it vibrates quite a bit... not to the point that its hard to control but enough to send any female in to orgasmic seizures. I wanna know whats up to? It cant be abs because i dont have abs... and its hard to imagine there being some kind of electronic malfuntion...
Old Feb 14, 2003 | 10:32 AM
jin kazama's Avatar
Re: What's up with my car!?!?!
that could be the problem there.. get your tires balanced or something. get them checked out.usually when a car shakes at 50+mph it has to do with tires/wheels. but then there are other things also. but thats just my guess
Old Feb 14, 2003 | 08:02 PM
I'm with Stupid's Avatar
Check the tires inflation, the wheels balance and the alignment. It's probably one of those things.
Old Feb 15, 2003 | 12:37 AM
DCTperformance's Avatar
Lightbulb i've got the solution to your problem.
It's called a pregnant tire. Or so it's called by the tire specialist's round my part of town. all's you gotta do is change the tire and your problems are as good as gone. I'm speaking from experience, I've had this happen to me. hope i helped.
Old Feb 15, 2003 | 07:50 AM
kaos's Avatar
Does it pull to one side pretty noticeably when you let go of the steering wheel? If so then it is either your tires need to be balanced or alignment.
Chad
Old Feb 15, 2003 | 11:28 PM
Jenn240's Avatar
Thanks guys I really appreciate it. I'll try those things out!
Old Mar 7, 2003 | 06:28 PM
Jenn240's Avatar
I finally found out what It was. I had a hung up calipher and a warped rotor (plus abad brake lines) . I fixed it and now it drives perfect! Thanks for all your suggestions!
Old Mar 8, 2003 | 11:17 AM
leiferik1's Avatar
[B I had a hung up calipher and a warped rotor (plus abad brake lines) . [/B]
that would have been the first thing i checked.....
epp_b
Aug 25, 2006 07:20 PM
ArticDragon
Jul 11, 2004 09:19 AM
polishmafia4u
Nov 8, 2003 05:55 AM
TruDirtyPlaya
Aug 19, 2003 10:19 AM
