Southeast FL, GA, SC, AL, LA, MS, TN
DRIFT EVENT: Nashville Superspeedway OCT. 7TH, 2006
Old Sep 18, 2006 | 04:59 PM
nismonkey's Avatar
Thumbs up DRIFT EVENT: Nashville Superspeedway OCT. 7TH, 2006
All day practice drifting event at:
Nashville SuperSpeedway
4847-F McCrary Rd
Lebanon, TN 37090
Directions to NSS can be found at the following link:::
http://www.nashvillesuperspeed...s.php
October 7th, 2006
Registration & Tech: 8:00am - 8:45am
Mandatory Driver's Meeting: 8:45am (DO NOT BE LATE IF YOU PLAN ON DRIVING)
Cars on Track: 9:00am - 6:00pm
Pre-registration $75.00
Day of Event $100.00
Spectators are $5.00 all day.
Passengers are $10.00 at the gate. valid all day
if at all possible, when pre-registering, please do not include the passenger payment with the driver payment. We ask that you please pay at the gate.*cash only*
Pre-Registration Ends on October 1st at Midnight
You must bring a copy of your registration receipt to the event.
NOTES:
1. There will be a 50 DRIVER MAX, To make sure that everyone gets PLENTY of seat time. Once we reach the 50 DRIVER LIMIT THAT'S IT.
2. ALL DRIVERS NEED TO ARRIVE BETWEEN 7:30-8:30AM. If you are paid and do not arrive by 8:30AM, your registration will not be accepted. This will be 100% enforced.
3. General tech inspection guidelines --
a. Battery tie down -- you must have a strong battery tie down (preferably metal). Bungee cords are no good. Do not even bother getting in the tech line if your battery is not secured well. Battery boxes must be similarly secured.
b. Seat belts -- you must have a functional 3 (or more) point seat belt that is securely fastened.
c. Seat bolts -- make sure all your seat bolts are tight and present. You will not be able to drive with less than 4 bolts holding your seat to the chassis.
d. Lug Nuts / Studs -- you must have all lug nuts and studs per wheel. 3/4 or 4/5 lugs/studs fails tech. No exceptions.
e. Wheel bearings -- must not exhibit excessive play.
You must be 18 to drive by yourself. If you are a licensed driver under 18 and would like to participate, you must have a parent or guardian present with ID to sign the minor waiver.
Event Sponsors:
Top Hat Performance
For concerns/questions concerning the event may be directed to stephen@southeastdrift.com or by going to http://www.southeastdrift.com
DGTrials.com
May 19, 2008 08:09 PM
eddiec
Nov 30, 2006 10:10 AM
edgar
Upper Midwest
Sep 16, 2006 03:30 PM
VWhite_Turbo
Northeast
Feb 13, 2006 05:42 PM
