Adding pressure
Old Dec 12, 2008 | 12:08 AM
mr_canedo's Avatar
Adding pressure
I have an stock SR20DET on my hatch RPS I want to go from 7 psi to 10 psi or 11 psi. I tried searching this but i couldn't find anything on this. How simple is it to add a manual boost controller and would i need to modify or do something to make this change? any suggestions on how i can achieve this? Thx for your help
Old Dec 12, 2008 | 01:01 AM
its very simple and on the stock turbo i would not push past 15psi
check the how to section, i have write-ups on how to install MBC's
Old Dec 12, 2008 | 11:34 AM
shaban's Avatar
if you have the factory boost solenoid, just change the vacuum line going from the wastegate to the ic piping and it pushes you up to 11psi (iirc)
Old Dec 12, 2008 | 01:04 PM
just get a cheap mbc u can even make your own from home depot lol.
stock sr at 11psi is hardly breath taking i did get a good kick out of 15psi. now with my gt2871r at 10psi i make more then my stock turbo at 15 lol
Old Dec 13, 2008 | 12:12 AM
mr_canedo's Avatar
good looking out guys, Im new to this SR and turbos i was playing with the NA motors on my honda but ever since ive had this RPS ive had it stock and since the SR is gonna be passed along to my bro decided to play with it a little thats why i wanted to add more pounds to it. So if i say something obvious to you guys and new to me bare with me. THX.
I know i can boost the T25 up to 15psi with out mayor mods or opening the motor. But it it as easy as adding a manual/electric BC? and some vacum lines?
Old Dec 13, 2008 | 06:25 AM
yep didnt need to add vacuum lines thouh the boost controller splices into existing vacuum lines.
D Grade
Nov 29, 2005 10:00 AM
smokie700
May 5, 2004 08:25 AM
jagarozzo
Jan 13, 2004 11:39 AM
silviase1
Oct 28, 2003 01:39 AM
RNN14
Mar 21, 2002 08:42 PM
