Crank Pulley Bolt Removal???
Old Dec 26, 2007 | 01:24 PM
positron's Avatar
I've been reading up on how to remove the crank pulley bolt but the methods mentioned were for an engine in the car or on a engine stand. My engine is sitting out of the car on a skid so how should I go about removing and replacing the crank pulley bolt?
Old Dec 26, 2007 | 01:26 PM
nissandrift's Avatar
Impact gun to break it loose, or breaker bar w/something holding the flywheel/crank from moving.
Old Dec 26, 2007 | 01:41 PM
Impact is like heaven for a situation like that--then a gear puller jaw [3 claw works best but 2 claw is good too]
Big breaker bar and something wedging the flywheel is ok too, but a lot more annoying.
Old Dec 26, 2007 | 02:01 PM
even with impact somtimes it wont come out some guys at work hit it with their half inch guns wont come out then they come to borrow my Mac Tools Half inch impact gun 1000 foot pounds of torque in reverse and mine pulls them out np so a strong one is needed or just a breaker bar
Old Dec 27, 2007 | 07:10 AM
positron's Avatar
Thanks! No impact but I do have a breaker bar so I'll try that.
Old Jan 1, 2008 | 11:57 AM
positron's Avatar
I got my engine off that old tire and on a engine stand for my build and was able to rig something up to help me remove the crank pulley bolt.
I took the chain and links that I used to remove the KA...
put two flywheel bolts into two of the chain links and threaded the flywheel bolts in the crank...
and put one of the transmission bolts through a link and threaded it into the housing.
This chain and bolts kept the pulley from spinning.
Then I used a 27mm socket and a breaker bar to bust the crank pulley bolt loose.
Old Jan 1, 2008 | 01:10 PM
major props for the thinking, i never even thought about using the bolts..we always just had people hold it by wedging screwdrivers in the sprocket part lol
props for a hella clean motor too!
Old Jan 6, 2008 | 06:45 PM
LandinSR20's Avatar
yeah seriously your motor looks like my dinner plates.
bs280
Nov 6, 2006 09:30 AM
Purple240
Aug 1, 2006 06:46 AM
zeroGripS13
Jul 12, 2005 12:22 PM
thekage
May 9, 2005 10:43 PM
Casey240
Mar 24, 2004 08:04 AM
