knocking sound at idel
Old Apr 6, 2007 | 09:19 PM
FOSINGWO's Avatar
i have a 97 with black top sr recenly theres a knocking sound when im at idel
when i press the gas a little it goes away n then comes back when i release the gas... it kinda happen like once a day for a little while... any suggestions
Old Apr 7, 2007 | 12:55 AM
Levi SPL S14's Avatar
knocking or ticking?
IF its knocking..good by motor. If its ticking, could be a stuck lifter on its way out. Try running some marvel mystery oil right before your next oil change. That stuff help unclog ports and oil passages.
Old Apr 7, 2007 | 11:06 PM
FOSINGWO's Avatar
it felts like something is shaking a little.. you could really feel it when u start the car n when u turn the car off... n this start to happen after a oil change... i used to use greddy blue syn. but i could not get them anymore so i change to mobile one syn. on my last oil change.. could that be the reason..
Old Apr 7, 2007 | 11:09 PM
is it a noise or just a vibration? if its a vibration check your timing and spark plugs. If its a noise then you may need a rebuild.
Old Apr 8, 2007 | 08:10 AM
Durdan's Avatar
man.. NEVER put marvel mystery oil in your motor! if anything, run a little bit of ATF in you oil to clean it out, but i have a feeling theres no syrum that will help you. if you hold the throttle at about 3500 rpm or so, do you hear it?
Old Apr 8, 2007 | 10:09 AM
^ marvel mystery is just about the same as ATF. Ive never had a problem with it.
Old Apr 9, 2007 | 12:15 AM
FOSINGWO's Avatar
no as soon as i tap on the gas it stop n comes back once of twice when im at a stop. you could feel a little vibration on the gas padel
Old Apr 10, 2007 | 07:03 AM
Durdan's Avatar
remove the valve cover, and take off the plate thats above the timing chain. reinstall valve cover. make sure your oil level is good. see if that fixes it.
Old Apr 11, 2007 | 11:23 PM
240topend's Avatar
sounds like a rod knock to me i got the same thing time to rebuild
Old Apr 12, 2007 | 07:21 AM
Durdan's Avatar
i wouls say rod knock off the bat, too, but it usually doesnt go away with gas, it will come back at a certain RPM. ****, it could be anything including the alternator. ive had those knock before when the bearings go out.
Old Apr 16, 2007 | 11:19 PM
240topend's Avatar
timeing chain tensioner maybe hey durdan hit me up need to talk to you about a rebuild on sr your x partner need to find .
Old Apr 17, 2007 | 12:23 PM
Durdan's Avatar
i dont understand what that means
Old Apr 17, 2007 | 01:56 PM
what's your temp gauge read. if it hot enough and you forgot to connect the knock sensor your car will do that.
iv'e used atf and that mystery oil with no success when it comes to sticky lifters mobile 1 is what's worked for me.
jerry7784
Oct 30, 2006 10:29 PM
jackyliem
Aug 4, 2005 10:22 PM
jackyliem
Jun 12, 2005 10:03 PM
CaTcH_My_DRiFT
Nov 19, 2004 06:04 AM
sleighty
Mar 5, 2004 08:15 AM
