Poor idle problem!!
Old May 23, 2007 | 06:31 PM
boooosted's Avatar
Poor idle problem!!
Ok so Ive got a 89 240 with sr20det red top. the swap just got done about a week ago and after startup we have a really bad idle. almost as if 2 cyl arent firing all the time. All vacuums are fine, The injectors have 12v and are pulsing fine, and good spark. The plugs are carboned up so I know its running rich. What are some possible problems Im facing. thanks in advance.
Old May 23, 2007 | 06:59 PM
sr91240's Avatar
your maf may be bad
Old May 23, 2007 | 07:22 PM
boooosted's Avatar
the car wont even start when the maf is unhooked
Old May 24, 2007 | 05:09 AM
iacv possibly, clean it out. or mabey sr's dont have those?
Old May 24, 2007 | 08:27 AM
sr91240's Avatar
you should try bypassing the iacv put a rubber cap on it ant on the outlet from the intercooler pipe and turn down your idle some if you still have the problem its something else but i still recommend you bypass it because they fail alot on sr's i got this info from durdan a while back so it should be accurate he an sr genius
KerosineK
Aug 28, 2005 04:08 PM
uvamosk
Aug 12, 2005 07:31 PM
johna_99_99
Apr 28, 2005 06:34 PM
240Girl
Apr 15, 2002 01:26 AM
