Help, SR running odd
Old 12-20-2009, 05:10 PM
240smoke's Avatar
Alright well I have been having issues with my SR recently. The computer isnt throwing any codes, I have spark in all coils, injectors tested good, TPS tested good, MAF tested ok. Compression is good. And I tore my engine harness apart and put it back together. I was having this issue before I ripped my harness out.
When I start my car, my AFR starts out at 14.8 then slowly goes to full rich. Then I start to give it throttle under load and it leans out fully. And if I give it a little more throttle, it goes rich again then back to lean with full throttle.
I am able to pull my MAF plug off and rev it to redline which I dont believe I should be able to. I think its supposed to go into a safety mode where it limits the revs to 2500RPMs. I know my MAF wiring is ok because I just had my harness apart and did point to point testing on the whole thing.
when the engine has reached normal operating temperatures, it still runs like ****. But if I turn the ignition key to off then restart it, the car will run perfect sometimes. I am completely dumbfounded to this problem. Would an O2 sensor cause this?
Is my computer bad? Any suggestions would be great.
240smoke is offline
Old 12-20-2009, 05:55 PM
240smoke's Avatar
anybody?
I am currently testing this. I dont think this is my problem though because I am getting spark in all cylinders. just want to eliminate it as a possible problem.
240smoke is offline
Old 12-21-2009, 12:29 AM
240smoke's Avatar
anyone?
240smoke is offline
Old 12-21-2009, 02:25 AM
wow that sounds nuts bro.. yes you should go to safemode without your maf on.
try a known working ecu man.
Biggamehit is offline
Old 12-21-2009, 03:36 AM
goto be the ECU
its not the ignighter cause when that goes bad the car wont start at all
battosaii930 is offline
Old 12-21-2009, 02:56 PM
240smoke's Avatar
alright. I will see if one of my friends will let me try his ecu. the closest person with an SR is like 55 minutes away. haha.
240smoke is offline
Old 03-16-2010, 05:19 AM
angrymonkeyS14's Avatar
Just wondering what happened to your car was it the ecu?
angrymonkeyS14 is offline
LA_phantom_240
07-29-2007 10:36 PM
EAGLE 5
02-26-2007 03:55 PM
twofortyessex
03-16-2004 04:04 PM
ixcocoyxi
11-04-2003 03:28 PM
leiferik1
02-24-2003 02:23 PM
Quick Reply: Help, SR running odd
