sr20det help please
Old Mar 15, 2007 | 04:42 PM
schaffs240's Avatar
sr20det help please
i have a 1989 nissan 240sx. i just swapped a 92 sr20det into it. i just got everything hooked up and a few exhaust leaks finished. i now have a new problem. i crank over my engine and it cranks over quite fine but it does not run perfect. it stutters and sounds like its going to die. but never does. it almost sounds like its running 300 to 500 rpm's but i dont know for sure because my gauge doesnt work. i just replaced the spark plugs. its also smoking black. im wondering if anyone knows what i could try to do to fix it.
Old Mar 15, 2007 | 04:46 PM
sounds like its idling really low? how about bumping up the idle? or maybe the timing is slightly off?
Old Mar 15, 2007 | 04:48 PM
schaffs240's Avatar
it idles up and down so i think that i should get it at a constant idleing first. do u know right off ur head what the timing should be at.? or anything else that it might be? the guy i took it to.. says that he timed it. :S
Old Mar 27, 2007 | 04:30 PM
90 Sileightyguy's Avatar
15 degrees.
Chris
Old Mar 27, 2007 | 05:06 PM
sr91240's Avatar
wut type of gas is in it and did you change the fuel filter also is it leaking at all at the headgasket
Old Apr 13, 2007 | 06:26 PM
drifttwo40's Avatar
If you rise up the rpm let say about 2000 does it run good.
Old Apr 14, 2007 | 12:54 AM
Levi SPL S14's Avatar
could be vacuum. Try spraying carb or brake cleaner around the intake manifold and the hoses.
also sounds like your running rich, you could have a bad temp sensor as well.
Factory is 15, ive had cars that liked 18 alot more. Also had a car that ran great 30 off, that was a weird one.
Old Apr 14, 2007 | 06:58 AM
yea definately try the carb cleaner, or also you could make a little boost leak tester to check too. make sure the maf i working correctly.. ive always ran my timing 17-18..
Old Apr 14, 2007 | 02:45 PM
Durdan's Avatar
if its running with black smoke and running poorly, make sure all your pipes are connected well. if it was a vacuum leak on the intake manifold, you would hear a defined hissing sound.
Niss240sxse
Mar 16, 2006 06:27 PM
jcl666
Jun 28, 2005 12:09 PM
japporeyser
Apr 7, 2004 08:15 PM
mel_ms
Jul 26, 2003 07:32 AM
chainz
Apr 13, 2003 03:12 PM
