Starting my sr powered S14
Heres the car
Started the rip down
Heres the motor
Engine Crane
More pics are coming planning to be done by the end of march.
My part list includes:
-GT28RS Turbo
-Step 2 cams
-Z32 MAFS
-stage 2 clutch
-LSD Diff.
-Power fc
-HKS FMIC
-Aluminum Radiator w/ Dual electric fans
-255 Fuel pump
-B&M short throw
-550cc injectors
-maybe big bore need to do more research about.
Advice would be well appreciated im sorta new to 240s
Also on the car already is:
-3" HKS header back
-K&N Intake
-Carbonfiber Hood
Heres the motor
Engine Crane
-GT28RS Turbo
-Step 2 cams
-Z32 MAFS
-stage 2 clutch
-LSD Diff.
-Power fc
-HKS FMIC
-255 Fuel pump
-B&M short throw
-550cc injectors
-3" HKS header back
-K&N Intake
-Carbonfiber Hood
Theres been alot of progress
Yanked the motor
Ripped down the block
Not to bad
Some build up
Machining:
-Got it bored .5 over for my wiseco pistons
-Polished and balance crank
-All new engine bearing
-Port and polish
-B.C. springs
-RAS
-New oil pump, pan, water pump, cam gears, chain and guides
-stage 2 B.C. cams
-ARP rod bolts
Thats about everything motor wise.
I'll have my assembly pix up soon cuz i just got the motor back yesterday.
Boostage!!!
-Garret gt2871r .86a/r
-Greddy FMIC
-Hks SSQV
Test fit
Bangin
1/2 my grad $
So much better
Electronics:
-Top zero TT
-Apexi AVC-R(200 of a friend sweet!)
-Autometer Boost, Oil pres., and A/F ratio gauges
Dash
Pillar Gauges
More build info and pix soon!
Not to bad
Some build up
Machining:
-Port and polish
-B.C. springs
-RAS
-stage 2 B.C. cams
-ARP rod bolts
Boostage!!!
-Greddy FMIC
-Hks SSQV
Test fit
Bangin
1/2 my grad $
So much better
Electronics:
-Top zero TT
Dash
Pillar Gauges
