Starting my sr powered S14
Bottom End Assembly!!
Desided to dedicate today to the lower end. 5 hrs total. Appologize for the blurry pix my gf sucks at taking pix
Installed the crank, ACL crank bearings, thrust washers, and freshly cleaned piston coolers. All torqued, loosened, then retorqued in order.
Me torquing(if thats how you spell it)
Done!
Next is pistons
Wiseco 86.5 Forged
I put the rods with hardened ARP studs installed on the pistons and filed the ring gaps for turbo apps.
Rings, check
1 by 1 in they go.
Even with a snap-on ring compressor it was still a PITA and needed a little help. I use a plastic body tool i had. It worked perfect
That's all for now. I'll have more top end pics soon. I just picked up my head the other day. Its coming along
Done!
Next is pistons
Wiseco 86.5 Forged
Rings, check
1 by 1 in they go.
Power Housed on it this week.
I pretty much finished up this week. Its a actual motor again. Mad pix!
Arp Head Studs
New Front cover, Cam chain + sliders,and gears
Crank Pic and baffle plate
Oil Pan Mad clean
Done
Cleaned Mani
Painted Fuel Rail Caps and Polished Rail. 740cc Injectors too!
Installed polished Head w/ Cometic Gasket
Stage 2 BC Cams, BC springs, Greddy R.A.S. and new rocker arms
Valve cover and polished nuts installed. Half my pullies
I call it the Blurple top
Oversized Oil Pan
How it looks as of tonight. Its coming
Arp Head Studs
Oil Pan Mad clean
Done
Cleaned Mani
Oversized Oil Pan
It runs!!!!
Alotta Work in 5 days but it was all worth it!!!
Spec Stage 2 clutch
Suspended ready to go in
1oclock in the morning but it was in
Silvia badges whut whut
Rad & Permacool Fan
Mad sick engine bay pic
And Another
No bumper haha
Straight Sex
It basically started 1st crank. Im pretty proud that there isnt any mess ups in my harnes and my complete rebuild. Let me know what you think
Spec Stage 2 clutch
Rad & Permacool Fan
And Another
No bumper haha
Straight Sex
Davidss
Jul 29, 2007 07:58 PM
Excellent job!!!!!
