2002 sentra rotors with 350z calipurs???
Old Feb 4, 2004 | 10:07 AM
irax's Avatar
Hey guys i was at a nissan dealership the other day, and the salesmans personal car was 2002 sentra 4 lug, but he got 350z calipurs... would it be possible to do that to a 240 ? get sentra rotors and put 350z calipurs ? as a more.. update break conversion ?? all the break conversions i see are for front breaks.. how come no one upgreads the rear ? and is it possible to upgread the rears with the same as the fronts ????
Old Feb 4, 2004 | 10:18 AM
Arent sentras bolt pattern 4x100? Dont know if that will work...You can upgrade the rear, but not everyone does because since the braking is mostly done in the front they feel thats all they need. You cant upgrade the front to the rears.
Old Feb 4, 2004 | 10:24 AM
irax's Avatar
woot responce already! computers at college kick ***.. anyways... what would i use to upgread the rears ?? the same as the rears from the breaks i would be getting ?? like if i get sentra rotors, and 350z calipurs.. i should get the front and rear of both ?
Old Feb 4, 2004 | 10:26 AM
http://www.saltgod.org/terry/terry.html then look at rear brakes.
Old Feb 4, 2004 | 03:36 PM
barrigaS14's Avatar
i think that they tired the new calipers from the 350z and the mounting points did work well. but anyways go with Z32 brakes front and rear. the rears are going to be a little more work if you want the e-brake still. with that setup though you have to upgrade the master cyclinder so that the pedal feel is better.
Old Feb 4, 2004 | 04:24 PM
irax's Avatar
for the Z33 or Z32 do i need an upgreaded master cylinder ?
Old Feb 4, 2004 | 06:43 PM
Its best if it you, dont know if its mandatory...but i would
Old Feb 5, 2004 | 08:45 AM
barrigaS14's Avatar
most people with the front calipers upgraded they don't do it. but if you do front and rear they usually do. i have drove in only a car with the stock cylinder and front Z32 brakes and it felt good. would like to try it with the master replaced.
superkeege
Oct 28, 2005 11:16 PM
jdmsoarer
Nov 23, 2004 05:24 PM
shane_lxi
Nov 4, 2004 02:32 PM
Ryan
West Coast/Hawaii
Apr 8, 2002 02:54 PM
ANF Dayne
Feb 10, 2002 09:19 AM
