300zx brake clearance questions
Old Dec 6, 2006 | 12:18 AM
white_rms13's Avatar
I own a 1992 240sx hb that is currently running 17x7 +42 with 5mm spacers all around.And it has Tein HE suspension too. Its ****ty, i know. But i was wondering if the z32 brake swap would fit. Even if it were just the 26mm alum calipers. I'd prefer the 30mm iron ones though. Would i need to run extended studs and spacers, and if so about how big?
oh and the rims look like this:
http://www.wheelspecs.com/specs/imag...anthracite.png
All suggestions are appreciated.
Old Dec 6, 2006 | 06:56 AM
re037's Avatar
personally, if i was gonna go z32 brakes id save up and do brakes, 5 lug, rims/tires all at the same time. but if youre not tracking the car, i dont see why youd need z32 brakes in the first place. pads and ss lines is a decent setup for most drivers
Old Dec 6, 2006 | 07:54 AM
Zenki_SliderS14's Avatar
mah *****h
the wheels are okay tho.
Old Dec 6, 2006 | 10:59 PM
hmm well i still want to upgrade just to have better brakes in general. but yeah, still wondering about the fitment..... lol
but thanks anyway.
Old Dec 9, 2006 | 01:27 PM
Clowny's Avatar
the 26mm will fit under some of the stock 240 wheels. the 30mm will fit under those same wheels with only a 5mm spacer. so if you are runnin those 17s, i dont see why your 5mm spacers wouldnt do the trick in clearing the iron calipers. If you find that they dont, just go with a 10mm spacer and some nismo extended studs.
Old Dec 9, 2006 | 03:53 PM
alright thanks a lot
bodiesenmotion
Feb 17, 2006 12:30 AM
NISMOVA
Jun 14, 2004 09:54 PM
TurboEvo
21
Feb 22, 2004 10:10 PM
Massimo
Jan 25, 2003 04:16 PM
dkdeleon
Nov 14, 2002 11:33 AM
