300ZX Brake Question???
Old Oct 29, 2006 | 02:58 PM
stealth_180SX's Avatar
Question 300ZX Brake Question???
was wonder bout the 300zx... when ur doing the conversion... do u need the rotors to or can u just use the 240sx stock rotor for it... if u do need the 300zx rotors can u drill it to the 4 lug spec...
Old Oct 30, 2006 | 02:00 PM
You need Z32 (300zx) rotors, and yes you can redrill them to 4 lug.
Old Oct 30, 2006 | 02:01 PM
alrite thankx
Old Oct 31, 2006 | 12:40 AM
jdmflavor510's Avatar
just wondering if i convert to 300zx calipers, do i need to replace the master cylinder with a bigger one? i have a fairly new master cylinder, and i don't want to spend the extra cash if i don't need to. thanks.
Old Oct 31, 2006 | 06:30 AM
I'm pretty sure you can still use the 240sx Master Cylinder but 300zx makes more sense to have because the 300zx set is larger, etc.
Old Oct 31, 2006 | 06:19 PM
Levi SPL S14's Avatar
american schools are failing us.
Old Oct 31, 2006 | 07:33 PM
indeed, they failed to teach me the forum search technique
Old Oct 31, 2006 | 07:34 PM
re037's Avatar
wouldnt the redrilled 300zx rotor be off balanced?
Old Oct 31, 2006 | 07:36 PM
its pressed against the hub with about 100ft lbs of force...theyre is no balance to be maintaned...only rigitity...which is still fine.
Old Oct 31, 2006 | 07:57 PM
If it was off balance or lacked integrity i sure they wouldnt be made or modified.
Old Jan 3, 2007 | 03:45 PM
jcl666's Avatar
wil the 300zx brake caliper bolt right up the the original s13 adaptor?
Old Jan 3, 2007 | 05:04 PM
Clowny's Avatar
yes it will, it says so in about 3 million different places on the internet. im sure at least a hundred of those are on here. hell i would be willing to bet you could google it and get that info.
Old Jan 4, 2007 | 02:26 PM
http://importnut.net/300zxbrakeswap.htm
bodiesenmotion
Feb 17, 2006 12:30 AM
aallbbeerrttttt
Feb 5, 2006 04:19 PM
chansuifei
Jul 21, 2005 06:13 PM
NISMOVA
Jun 14, 2004 09:54 PM
dkdeleon
Nov 14, 2002 11:33 AM
