-   Suspension, Chassis, and Brakes (https://www.s-chassis.com/forums/suspension-chassis-brakes-15/)
-   -   300zx Coilovers in 95 s14 (https://www.s-chassis.com/forums/suspension-chassis-brakes-15/300zx-coilovers-95-s14-45524/)
po_bo Mar 9, 2009 07:04 PM
I upgraded my s14 brake calipers to z32 calipers, and i bought a used 300zx rear e-brake assy on line, and lucky it come with the alum knuckles, and is such a wast not to use it on my s14, but i find out i need z32 strunts for the rear, so im planning may aswell upgrade it too, so i need z32 coilovers, but before i buy one could any body tell me if the z32 front strunt mount holes are same as s14? will z32 front coilovers bolt directly in to my s14 front knuckles (upright)? or should i keep it simple and just forget about the alum knuckle and get s14 coilovers? i also heard magen coilovers makes a sleeve that will fit rear z32 knucle, but how about the front? any body done a swap like this before? please help me out thanks!
silviaks2nr Mar 9, 2009 10:47 PM
no it's not going to work. you will need s14 shocks/struts/coilovers
po_bo Mar 10, 2009 10:26 AM
so 300zx front strunt/coilovers won't bolt on to s14 front knuckle/spindle. ok then my plan is to get magen coilovers for s14, then i will also get the rear strunt lower sleeves from magen to fit the rear coilover to the 300zx rear knuckle. will this work?? is magen coilovers good? are they good brand? or is there other coilovers that are better and will work?? thanks!
shaban Mar 10, 2009 10:42 AM
There are much better coilovers than Megan, but Megan is a good cheap brand of coilovers. I suggest stance gr+
po_bo Mar 10, 2009 12:15 PM
Does stance gr+ have rear strunt lower sleeves? Like the magen does, where i can fit s14 rear coilovers to 300zx rear knuckle/upright? Thanks!
shaban Mar 10, 2009 12:30 PM
The Megans you can fit over any coilover I believe.
silviaks2nr Mar 10, 2009 12:59 PM
why are you using a 300z rear spindle? are you doing a 4-5lug conversion? just swap the hubs
FuriousZ Mar 10, 2009 01:22 PM
i Think he wants to use the 300zx aluminum knuckles for the rear. I think you can fit any rear coilover that was made for the rear 300zx.
Originally Posted by positron (Post 334092)
I did the Z32 rear brake upgrade today...
blah blah
http://i130.photobucket.com/albums/p...2/IMG_1277.jpg
Here's the comparison between the 240SX spindle(top) and the Z32 spindle(bottom). The 240SX spindle is iron where the Z32 is aluminum. I would have liked to use the Z32 which is 7lbs. lighter but I would have had to get coilovers or Z32 shocks/struts because as you can see the only thing different is where the strut to spindle mounts are. They are completely different.
http://i130.photobucket.com/albums/p...2/IMG_1279.jpg
I think this should help this thread.
Rmetler Mar 10, 2009 02:34 PM
SPL-Parts, the make there own coilovers that have the option for Z32 rear knuckles. They have gotten pretty rave reviews on other forums SPL KTS coilovers
http://splparts.com/main4/index.htm
