5 lub conversion and wide as$ wheel question
Old Jul 20, 2003 | 10:55 AM
2k2xsexima's Avatar
i might get te37's if someone can answer these questions.
im planing to run 245/40/17 on the front w/ a 8.5" rim and 275/40/17 in the rear w/ a 9.5" rim.
i am also about to do a 5 lug conversion.
i wanted to know what i would need to do to make this set up work.
oh...the rims are 40 offset
when switching to the 5 lug conversion, doi ONLY need the hubs in front? the front hubs come w/ the bearings right?
i have a messed up bearing in the rear, do the rear hubs come w/ the bearings too?
are the hubs the only thing i need to do the conversion?
(i've searched, most people replace everything. not just the hubs. i was wondering if i can just replace the hubs)
now when i install my rims, i was thinking about switching out the wheel studs for longer ones,(hopefully a 3" arp wheel stud) and adding wheel spacers to the front and rear.
would this be a good set up? i need to know how much space i need between the hub and the wheel.
would it be ok to install like 4 5/16" spacers on each side of the rear? should i not get the studs for the rear and buy like 2 of those 1" spacers that come w/ the studs?
will this be a safe? will i need more space in the rear?
thanx for your help in advance
david
Old Jul 21, 2003 | 02:42 PM
SHIFT_Lock's Avatar
too many questions at once.....all that and i don't think i read the most important peice of info..is it a s13 or 14?
Old Jul 21, 2003 | 11:19 PM
2k2xsexima's Avatar
i have a 95 S14
basically i want to know
1. how much space will i need to fit 8.5 rims in the front and 9.5 in the rear?
2. would it be safe to use ARP extended studs and put like over an inch of spacers on the car? if not, what should i do? keep in mind that im a VERY SPIRITED driver.
3. are the HUBS the ONLY thing ill need for a 5 lug conversion?
THE ONLY THING? do the rear hubs come w/ the bearing like the front?
OutToWinPAHC
Jun 10, 2007 02:41 PM
renegadeboy00
Aug 28, 2006 08:31 PM
SiLFoRty92
13
Mar 22, 2006 02:05 PM
BigBump
Aug 5, 2004 11:07 AM
YB-legal
Jul 31, 2004 02:22 PM
