5 lug conversion
5 lug conversion
where do the parts come from for the conversion? i'm guess you need a nissan donor like a 300z or something?
also what would the lug spacing be changed to? does it go to 5x114?
i ask because i plan on doing this before i get wheels. if i can use 5x114's i can look at FD3S RX7 rims and ask for different offset.
For the rear all you need is the hub. For the front it of a S13, you can either get JDM S13 5 lug hubs and be set. Get S14 SE hubs, S14 spindle and S14 ball joint with LCA(you have to re-drillthe strut for a larger bolt), or buy 4 to 5 lug hubs from jspec http://jspec.com/4to5lughub.html (best option probably)
If you have a S14, all you need are the S14 SE hubs and thats it
i have a 89 240 and i want to do the 5 lug conversion and i'm still kinda confused about what i have to do also. from reading
-HyJynx-'s reply it sounds like all i need is are:
GTO 4 to 5 Lug Hubs from Jspec
then for the rear i just need s14 se hubs
am i correct with what i need?
Originally posted by Driftin RPS13
so u cant use the Z32 hubs on the frotn of a S13???
They sell the kit in Japan, it is quite costly. You also are going to have to change your rotors ect. ect. ect. I have had good luck with universal wheels and I have put too much money into my brake system to change the whole thing. I say stick with the 4 lug and save the headache!
Driftmonster
Driftmonster
ok i didnt want to start another thread so here is a question regarding 5 lug and more!!!!
if im using rear Z32 brakes and im using rear Z32 uprights, how will this work when i order coilovers etc.. are the bottome parts interchangeable(Z32 Fork style 240 other) or do i have to order Z32 rear suspension???????
does anyone know what i mean
thanks
thanks
http://sportcompactcarweb.com/projec...cc_projsilvia/
http://importnut.net/300zxbrakeswap.htm
i think they are interchangeable, i just hope that tein HE offers interchangeable mount
