5Zigen FN01R-C Rims
Hey guys I have decided to go with 5Zigens FN01R-C rims but im not sure what sizes will clear my Z brakes?? When it comes to rims and tires I have no idea what all of the numbers correspond to as far as sizes go, I dont understand what offset is?? Anyways you guys wanna help me out here and suggest what size I should order, I want to have a 17 inch rim that looks flush and clean, thanks. Peace
17X8 offset +25 all around.
http://www.tirerack.com/wheels/tech/offset.htm That should explain offset pretty damn well |
dude 17x9 +15 offset
Ok so if I have this right the that Catharsis suggested will be deeper and and wider right?
Originally posted by KozyNissan Ok so if I have this right the that Catharsis suggested will be deeper and and wider right? |
Ok I want to have wider rims in the rear so could i have 17x8's in the front with a +25 offset, and 17x9's in the rear with +35 offset, or is that not going to fit or look weird in any way??
The rears will be sunken in more than the fronts won't they? +35 is a little high.
+25 all around if you want a staggered set up
will 17x9 +35 up front and 17x10 +35 rear be suitable on a s14 as in flush and so forth
Far from it!
what do u recommend, i have eibach sportline with agx
17x9 +15
17x10 +12 |
wheel offset has is not the main cause for caliper clearence...it is spoke design.
