5Zigen FN01R-C Rims
Old Oct 14, 2004 | 09:13 PM
KozyNissan's Avatar
5Zigen FN01R-C Rims
Hey guys I have decided to go with 5Zigens FN01R-C rims but im not sure what sizes will clear my Z brakes?? When it comes to rims and tires I have no idea what all of the numbers correspond to as far as sizes go, I dont understand what offset is?? Anyways you guys wanna help me out here and suggest what size I should order, I want to have a 17 inch rim that looks flush and clean, thanks. Peace
Old Oct 14, 2004 | 11:44 PM
17X8 offset +25 all around.
http://www.tirerack.com/wheels/tech/offset.htm
That should explain offset pretty damn well
Old Oct 15, 2004 | 11:15 AM
Catharsis's Avatar
dude 17x9 +15 offset
Old Oct 17, 2004 | 04:44 PM
KozyNissan's Avatar
Ok so if I have this right the that Catharsis suggested will be deeper and and wider right?
Old Oct 17, 2004 | 10:04 PM
It will be wider, not deeper
Old Oct 19, 2004 | 07:15 PM
KozyNissan's Avatar
Ok I want to have wider rims in the rear so could i have 17x8's in the front with a +25 offset, and 17x9's in the rear with +35 offset, or is that not going to fit or look weird in any way??
Old Oct 19, 2004 | 10:21 PM
ArticDragon's Avatar
The rears will be sunken in more than the fronts won't they? +35 is a little high.
Old Oct 19, 2004 | 11:45 PM
+25 all around if you want a staggered set up
Old Oct 24, 2004 | 10:04 AM
s14junkie's Avatar
will 17x9 +35 up front and 17x10 +35 rear be suitable on a s14 as in flush and so forth
Old Oct 24, 2004 | 11:49 AM
Far from it!
Old Oct 24, 2004 | 12:04 PM
s14junkie's Avatar
what do u recommend, i have eibach sportline with agx
Old Oct 25, 2004 | 02:44 AM
stealthyS14's Avatar
17x9 +15
17x10 +12
Old Oct 25, 2004 | 09:35 PM
barrigaS14's Avatar
wheel offset has is not the main cause for caliper clearence...it is spoke design.
yektik99
Apr 21, 2005 10:55 PM
Emopunk96
May 5, 2004 01:51 AM
yektik99
Apr 10, 2004 08:55 PM
Sil80guy
Mar 9, 2004 10:29 AM
Suhster85
Mar 6, 2004 12:05 PM
