adding parts only to find you need more
So i just finished installing my tein flexes and tein t/c arms. And as soon as i pull the tire off i notice that my ball joint bushing is completely split around the middle and to top it of my tension bushing is totally screwed only good thing is that i was replacing the tension arm but now i have to get new ball joint. I mean they don't cost much 27 dollars but damn i wanted to check out my new setup not to mention that i have to remove control arm and get the new ball joint pressed in.
Damn i love working on the car. P.S. If anyone has a write on how to change the tie rod/ends it would be helpful i have those but was gonna let the alignment shop install them. |
Re: adding parts only to find you need more
Originally posted by smokie700 So i just finished installing my tein flexes and tein t/c arms. And as soon as i pull the tire off i notice that my ball joint bushing is completely split around the middle and to top it of my tension bushing is totally screwed only good thing is that i was replacing the tension arm but now i have to get new ball joint. I mean they don't cost much 27 dollars but damn i wanted to check out my new setup not to mention that i have to remove control arm and get the new ball joint pressed in. Damn i love working on the car. P.S. If anyone has a write on how to change the tie rod/ends it would be helpful i have those but was gonna let the alignment shop install them. |
yes but it was ggod to know thatinstead of upgrading im upgrading a bad part
