Big Brake Kit ? ?
Old Mar 16, 2004 | 02:26 PM
KAZILLA's Avatar
Big Brake Kit ? ?
I have seen that some bracket of some sort can be added on
if (found on ebay) one currently has the front 300zx calpiers
(30mm) on their 240sx. It allows one to upgrade from the 11"
rotors found on the Z32 to the 12.5" rotors found on the 3000GT
VR-4.
Just wanted to know if this is mechanically possible or is this a
scam? Thank you fellas for any input...
Old Mar 16, 2004 | 04:13 PM
I believe your talking about the 300zx(Z32) brake conversion. It is possible, and Search around the forums to find more info on it.
Old Mar 16, 2004 | 08:02 PM
JeromeS13's Avatar
Actually, he's not. He is talking about, as he said, coupling the Z calipers with some even larger diameter rotors.
Yes, it is possible. John B. here in ATL is about to fab up some brackets to use some Cobra rotors. IIRC they're ~ 13" in diameter...
As far as the bracket goes, its a plain thick sheet of metal made so that is moves the caliper outwards, away from the center-point of the spindle. That will allow for the larger diameter rotor. Keep in mind, you still have to keep roughly the same thickness on the rotor. No biggie, though.
Old Mar 16, 2004 | 08:16 PM
KAZILLA's Avatar
Thanks Jerome, wow 13" Cobra rotors thats stopping power!
Wondering if you could keep me updated to see how the Cobra
rotors work?
Old Mar 16, 2004 | 09:23 PM
Gotcha, read it wrong
Old Mar 17, 2004 | 08:47 AM
JeromeS13's Avatar
rotors work?
I will. But, if you're only driving on the street, larger diameter rotors will not benefit you at all. The purpose behind the larger rotor is better heat capacity and dissipation. Long track events, or constant hard braking will result with less brake fade...
turbed240sx
Apr 8, 2005 04:20 PM
s14flame
Jan 18, 2005 11:24 AM
joe3180
Sep 10, 2004 06:19 AM
skyz315
Oct 15, 2003 04:05 PM
importer9
42
Jul 28, 2003 10:13 AM
