Brake Piston
Old Sep 1, 2002 | 06:24 PM
Driftin180SX's Avatar
Brake Piston
We were changing mah open differential to a VLSD off of a S13 in japan, in the mean time we wanted to change the brake pads for the rear, but the problem we ran into was dat the brake pistion wouldnt move at all so we couldnt push it back. We used some C-clamps but dat still didnt work, so i was wondering if u guys had ne ideas or solutions dat might be able to help me solve the problem? The car brakes fine and everything. Thx for helping
Old Sep 1, 2002 | 07:49 PM
S13drifter's Avatar
I had the same problem, the rear dise brakes on the 240sx have to be turned clockwise to get the piston to moveback in. It has to do with the e-brake. I used a c-clap but it has to be turned so i took it all the way of and i found that you have to turn it. If it does not turn clockwise in then you have to take it out because there is probably rust inside. Then you can spin it back in.
Old Sep 1, 2002 | 10:36 PM
Thanks for the advice.
Old Sep 1, 2002 | 10:42 PM
S13drifter's Avatar
BTW where did you get you VLSD and how much you pay for it, i'm looking for VLSD so it would help me out. thanks
Old Sep 2, 2002 | 12:34 AM
i got mah LSD from jspec.com for $320. it came with the half shafts too so it was a good deal. the guy only had 1 left after i took the one i wanted. the VLSD works great
PissonH
Sep 14, 2004 02:19 PM
jackyliem
Aug 17, 2004 07:00 PM
Casey240
Nov 21, 2003 07:04 AM
skyz315
Oct 15, 2003 04:05 PM
KingKA
Sep 27, 2003 11:50 PM
