Brake Pressure.
recently i installed new pads and rotors. after that i suffered from no brake pressure. i bled the brakes to the best of my ability because 3/4 bleeder valves are sciezed. adn i had to do it with the same technique but with the bolt holding the lines to the caliper to get the air out.
my problem is that i cant build up enough pressure to lock the brakes going 15km/h. button do work to a degree but when i pump the brakes while the car is on it almost stalls when it isnt warmed up. what can cause thease problems? what may be possable solutions? thanks, Kyle |
Moving To BRAKES/wheels/tires/suspension, hopefully you'll get more help there bud.
Dr. |
i got nothing there so i put it in general to see if i could get some more hits, i really need help i couldnt stop quickly if i had to so its kinda unsafe.
Re: Brake Pressure.
Originally posted by Drift-Obsession recently i installed new pads and rotors. after that i suffered from no brake pressure. i bled the brakes to the best of my ability because 3/4 bleeder valves are sciezed. adn i had to do it with the same technique but with the bolt holding the lines to the caliper to get the air out. my problem is that i cant build up enough pressure to lock the brakes going 15km/h. button do work to a degree but when i pump the brakes while the car is on it almost stalls when it isnt warmed up. what can cause thease problems? what may be possable solutions? thanks, Kyle |
yeah theres about a 70% chance that my master cylinder is screwed, but i see no fluid dripping out of it? what other ways could i check?
i didnt really have a choice at the time, my bleeder valves are sciezed as **** and one is broken off, lesson learned on that one, if it dosnt come stop tourqing so hard and try somthing else. |
oh yeah when i was bleeding the brakes there was a wierd milky color ot the brake fluid? WTF? it was the new stuff i just picked up and i was flushing the whole system. whats with this?
