Brake Proportioning (z32 front) and rear?
Old Aug 8, 2008 | 07:32 AM
award78's Avatar
hey guys,
Anyone care to give some feedback about their z32 brake setup. I just got a great deal on some z32 front brakes (not installed) but have stock rear calipers. First off, I hear you have to remove the whole hub and all arms for the rear z32 caliper instal and I just got it aligned PITA, not sure if that would affect alignment but I don't want to mess with it.
Will it be ok with 8 pistons up front and 2 in the rear? Any of you lock the rear up too easily with z32 brakes in the rear?
Basically what's your brake setup and how does it feel?
Thanks
Old Jan 10, 2009 | 10:15 AM
240SILV's Avatar
I have Z32 brakes front and rear with a z32 master cylinder which, in my mind is essesaryfor thebrakes to be biased, and function properly. I have had no problems withthis setup and thecar brakes well. The E-brake for the Z32 rear brakes is a little tricky to get to work well though.
Old Jan 10, 2009 | 06:16 PM
positron's Avatar
I've got stock brakes in the front and Z32 in the rear...no problems at all.
Old Jan 11, 2009 | 12:57 AM
its 4 pistons per caliper up front... there is nothing wrong with a brake upgrade.. if you are having issues... .whatever directions you followed may be wrong. with all the parts in front of you, it can be done in a matter of hours.
the only thing you will have to workout is the E-brake cable. many people have came up with their own ways of dealing with it. We should have a thread here on it, ill see.
rancidnsx
Sep 27, 2006 02:16 PM
nissans13
Aug 23, 2006 02:54 PM
VWhite_Turbo
Dec 21, 2005 02:37 AM
silviadriver
Mar 2, 2005 08:15 PM
