Brake Question
Old Feb 14, 2002 | 01:26 PM
240SEX's Avatar
*****istrator Jr.
Brake Question
I'm tyring to buy some KVR pads. Is it bad to use KVRs on stock discs? I am getting mixed signals from people. KVRs are gonna cost me 67 shipped but OEM pads will cost around the same if not more.
Old Feb 14, 2002 | 01:42 PM
PSM's Avatar
PSM
*****istrator
I got KVR's on mine and I think there pretty damn good. I've put a couple of track events on them and they still have LOTS of padding left. They dont dust much either.
The only 'bad' thing about them is that when they are very cold the pads make some noise when brakes are applied. But after a few brakes its all back to normal.
My braking overall is much better compared to OEM pads.
Old Feb 15, 2002 | 04:45 AM
battlestylespl's Avatar
try EBC Green Stuff, they work good, no heat up required. tirerack.com sells them.
Old Feb 16, 2002 | 05:22 AM
s14vaxlr8's Avatar
yep i agree
Old Feb 16, 2002 | 07:05 AM
Nightrider's Avatar
Get the OEM pads
Better be safe than sorry, don't **** with your car , get the the OEM pads and save some money.
Old Feb 16, 2002 | 07:46 AM
s14vaxlr8's Avatar
what are you saying that axxis, green stuff are bad for you brakes???
umm i dont think that there is too much tech ina brake pad other than the compound
but yeah get oem pads if you wanna clean your rims every day with a fkn steel brush
Old Feb 16, 2002 | 12:30 PM
PSM's Avatar
PSM
*****istrator
As far as the EBC pads I've heard they are not so great. Specially at the track. I've never used them so I cant give you personal tastes but I've heard they 'vanish' pretty quick (for track use at least.
I'm not sure how hard they are on the rotors either. Either way OEM would be a safe route if you dont plan on too much auto-x or track events.
Old Feb 16, 2002 | 12:46 PM
EBC makes different compounds for track use. green stuff is just a sport type pad.
Old Feb 16, 2002 | 03:58 PM
Silviaspeed's Avatar
I just finished doing a brake job on my 95 240. I used KVR carbon metallic pads with Brembo cross-drilled and slotted rotors. Stopping is very smooth, and consistent. Very good pads to get, also because they are carbon metallic they won't cause as much brake dust as say an asbestos based pad would. I like the KVR's, and suggest you get them. I've also heard very good things about Axxis metal masters, and Endless brake pads. The Endless also come in a special design which aids in drifting, how I don't know, but thats what they claim. It most likely has something to do with a certain technique used to induce the drift.
Old Feb 17, 2002 | 01:31 AM
Endless pads = $$$$
Old Feb 17, 2002 | 06:52 AM
I know man......they can get pretty damn expensive. But they're great pads.
Old Feb 17, 2002 | 06:55 AM
Autoimaging has them for $109.99 for the front and rear sets. Not that bad a price.
http://autoimaging.com/shop/index.cgi?ID=SSMZDD&task=show&cat=Suspension+%26+B rakes
For some reason this link isn't working....I'll try again.
Old Feb 17, 2002 | 11:57 PM
that's not that bad of a price
Old Feb 19, 2002 | 12:52 AM
RNN14's Avatar
EBC turbo rotors are also a nice setup. Mix that with Endless pads and Goodridge SS brake lines. I couldn't get a set of EBC's for my car so I went with Black Diamond in the UK and Endless pads with Goodridge lines.
Old Feb 19, 2002 | 01:37 PM
240SEX's Avatar
*****istrator Jr.
Hey knightrider, i guess you have had many problems with your 240. The first problem was the GTR badge..haahah j/k
jdmsoarer
Apr 21, 2004 12:49 PM
jdmsoarer
Apr 17, 2004 10:59 AM
jdmsoarer
Apr 6, 2004 05:56 PM
SlydeSHO
Jan 22, 2004 04:20 AM
dkdeleon
Nov 14, 2002 11:33 AM
