brake retailers?
Old Mar 23, 2004 | 08:32 AM
kable's Avatar
brake retailers?
ill probably get flamed, but i tried searching the forum and just found a lot of private for sale and google give links to a lot of threads instead of retailers....buttt....
do you guys have any sites that sell brembo blanks fairly cheap?
Old Mar 23, 2004 | 09:29 AM
http://www.2kracing.com/index.php/cPath/14_74_246
All I did was google "240sx brembo"
Old Mar 23, 2004 | 12:14 PM
kable's Avatar
o i just searched for brembo =\ thanks
Old Mar 23, 2004 | 02:29 PM
bishoptaner's Avatar
i got one cheaper http://www.mvpmotorsports.com/Templa...635&SearchYN=N try this
Old Mar 23, 2004 | 03:19 PM
kable's Avatar
thanks a lot...those are brembo blanks correct?
Old Mar 24, 2004 | 08:53 PM
JeromeS13's Avatar
Well, thats odd.... Both of those sites list slotted or cross drilled. But, none of those were blanks like he originally stated.....
Here ya go:
S13: NOPI Online
S14: NOPI Online
Old Mar 24, 2004 | 11:12 PM
kable's Avatar
alright thanks a lot, those were nice and cheap. i didnt know blanks were just a reference to plain rotors. are there any vented rear rotors? on all the sites ive looked i havent been able to find any.
Old Mar 25, 2004 | 04:06 AM
JeromeS13's Avatar
The 240sx rear rotors aren't thick enough to be vented.... You can find slotted/drilled, but none of them will be vented.
Old Mar 25, 2004 | 08:14 AM
kable's Avatar
ooh ok. would u suggest getting the cross drilled ones? would it make a difference over nonvented blanks?
Old Mar 25, 2004 | 02:40 PM
JeromeS13's Avatar
Cross drilled rotors are better for heat dissipation. For the money, I'd just use blanks in the rear because only about 20-25% of your braking is done there.
Old Mar 25, 2004 | 05:14 PM
ZenkiSE's Avatar
From: You know the dirty south...I live in the clean spot
ROME you PIMP i didn't know you came around these parts ...whuddup yo
Old Mar 25, 2004 | 10:28 PM
kable's Avatar
alright thanks a lot for the info guys. i picked up brembo vented fronts and brembo solids in the rear. installing them tomorrow, ill show u pics even tho it isnt anything special.
Old Mar 25, 2004 | 10:49 PM
rps13VEk's Avatar
GL man, i hope it comes out good.
Old Apr 21, 2004 | 09:41 PM
JeffSchmitt's Avatar
i heard that cross-drilled rotors were actually worse for heat dissipation, because when you drill them, you are taking away mass from the rotors, and how much material is in the rotors is important for how much heat they will hold. hmm...that wasn't very clear...basically what i'm trying to say is that the rotors will actually be hotter when they are drilled because there is less material in the rotor for the heat to occupy. also i heard that cross-drilled are more prone to cracking. slotted is the way to go. cross-drilled just look badass. correct me if i'm wrong.
Old Apr 22, 2004 | 12:13 AM
kable's Avatar
yeah cross drilled rotors do look pretty sweet. and what you're saying is correct, there is actually less metal/whatever to absorb the heat. i read somewhere that slotted rotors increase brake fade?
jdmsoarer
Apr 21, 2004 12:49 PM
jdmsoarer
Apr 17, 2004 10:59 AM
jdmsoarer
Apr 6, 2004 05:56 PM
SlydeSHO
Jan 22, 2004 04:20 AM
dkdeleon
Nov 14, 2002 11:33 AM
