can anyone find a coupe harness bar?
I think Sparco makes one as well as Cusco. Just check around the interweb.
www.aspec.com is what comes to mind at the moment.
Ruiz is retarded. It's www.aspecproducts.com
Be carefull with the idea of using a harness bar. You should not use a race harness without a roll bar or cage. Reason being a harness locks you into place, and in the case of a roll over, the roof will crush you. Witha regular seatbelt, you body can move much more freely to contort away from a caving roof.
be carefull about driving a caged car on the street. The top bars can be very dangerous in an accident without a helmet because you can hit them with your head and get serious injured. If you plan to street the car at all, consider something like a 6 point with low side forwards and no halo/upper forward bars and pad anything you could hit.
As for the harness bar...
http://cgi.ebay.com/ebaymotors/RACE-...spagenameZWDVW
As for the roll cage...
I read an article on modfied mag a while back about roll cages. I honestly wanted a roll cage but my 240sx is my daily driver. from what they were claiming it made alot of sense. Since most 6 point roll cages have bars in the front where in case of a front end collision your frontal lobe will smash into the bar (your fore head) They recommended that if your using your 240sx as a daily driver they would recommend using a rear only 4 point roll cage. That way there is not front bar above your head and all the bars are only in the rear. I've been searching for a roll cage just for installing my sparco harnesses correctly but haven't found one for a reasonable price but just my two cents. Anyways hoped that help good luck bro!
Bryan
Feb 14, 2006 05:26 PM
jenspec
Oct 30, 2005 11:23 PM
futureteg
May 26, 2005 11:10 PM
Hi Im Simon
Jan 28, 2005 06:55 AM
DriftingTiger
May 9, 2004 09:21 AM
