Dippin
Old Nov 19, 2002 | 09:24 PM
altima/240sx's Avatar
Dippin
on my 89 S13, i seem to be having a rear suspension issue. when ever i go over any obstacle, whether its a bump, hole, or any kind of change in the road other than flat, the passenger side rear end dips and seems to push outwards for some reason. I checked the struts, and they are fine, but i haven't jacked the car up yet to check everything, its been too cold. So I was wondering what would be a good place to start checking on the rear?
Old Nov 20, 2002 | 08:59 AM
Import Fanatix's Avatar
Check your arms to make sure the toe is proper and all the bushings that are there. That's where I would check.
Old Nov 21, 2002 | 08:47 PM
thanks, i will check as soon as the weather stops raining. plus i noticed, my tires are almost bald on the back
Old Dec 1, 2002 | 03:50 PM
it looks that it was my tires. i switched to my stock M & S tires since winter is officially here, and i don't have the problem anymore. My rear tires look like slicks on my custom rims
Old Dec 14, 2002 | 10:01 AM
thoraxe's Avatar
you have an alignment problem that you should get checked out.
you should also make sure that none of your rear sus arms are broken/damaged/bent
