found a 95 300zx tt with brakes still on it, can i use them on my 240sx
I was at a salvage yard today on came across a 300zx twin turbo. It had only been there for 3days"is what i was told" and the engine had already been hit up for parts, but the breaks, calipers, and rotors were all still there. I wanted to grab them for a big brake upgrade but i am sure on the steps and the parts "if i could even use the parts" that i would need to complete such a task. so could i use the parts off the 300????
1 Attachment(s)
All you would need to do is to get the 240sx-300zx conversion brake lines. The calipers will simple bolt on. I say get those along with the wheels because they have a better offset and are wider(7.5front 8.5rear) and more flush. Here are some pics of the Z brakes and TT wheels on my car........
1 Attachment(s)
pic of the wheel flushness........
Moved to brakes, post in the right area please!
Dude
300zx brake swap is one of the most common things done. SEARCH before you post PLEASE. Yes it can be done. If your 240sx is 4 lug you'll need to redrill the rotors, if it's 5 lug then you're good to go. Dr. |
