front suspension/drive noise / diagnosing question .. help!
Old Jun 30, 2006 | 10:32 AM
djradam's Avatar
Hello,
just wondering if anyone can provide some insight into this. lately i've had a "creaking" sound in my front suspension. i notice it most of the time when i'm slowing down and i've noticed it when turning into my drive and going straight. i can really only describe as a "creak".
i had similar sounding problems on my subaru and they changed the front axle because it was binding.
the 240 doesn't have that, so i'm thinking it's either the spindle, ball joint, or hub, or all of the above. i changed the tension rod bushings last summer, so i don't think it would be them
any help / insight is greatly appreciated.
thanks!
Old Jun 30, 2006 | 11:26 PM
re037's Avatar
id give the bearings a try
Old Jul 1, 2006 | 12:05 PM
djradam's Avatar
thanks, i was talking to my friend and he said that the polyurethane after a while can make noises too. that's what i put on the tension rods (the bushings from pdm racing).
i might deal with it now unfortunately :-/
Old Jul 1, 2006 | 08:10 PM
re037's Avatar
would the energy suspension bushings squeek too? theyre 3 piece unlike the one piece from white line.
Old Jul 8, 2006 | 11:29 AM
Badazz_240's Avatar
I had the same problem when my tension rod bushings broke.
Usually if they are not ruined (since you just replaced them), then it is because they were not greased properly/thoroughly enough
Just regrease them and you will be fine, or bust out your wallet and buy some ball type tension rods
---Useless but cool pic of my tension rod bushing ---
http://www.msnusers.com/My240SXPictu...oto&PhotoID=17
Very efficient right?
Old Jul 8, 2006 | 05:17 PM
djradam's Avatar
ah, pic isn't coming up! i didn't press them in, i had my friend take it to a shop so i have no idea what they did :-/ but thanks!
Old Jul 8, 2006 | 06:26 PM
Badazz_240's Avatar
they tend to not like working.... I think the site is becoming more worthless by the minute
Old Oct 27, 2006 | 05:47 AM
positron's Avatar
Have you tried the top bearing mounts? Before I replaced them my car would make a grinding sound when I turned the wheels.
s14Drifter
Sep 28, 2008 11:17 AM
nsn240
Jul 28, 2006 12:23 AM
re037
Sep 18, 2005 11:58 PM
ticklemeermuel
Mar 27, 2005 12:54 PM
driftndodge
Feb 5, 2004 01:33 PM
