Has anybody else experienced this creaking?
Old Mar 28, 2005 | 05:03 PM
LaDyInRed's Avatar
In my s13, there is a distinct creaking coming from the front while I'm coming to a stop during braking. I'm not quite sure, but I think it happens when I press harder on the brakes, but it's not a squeaking sound like that of worn brakes. It sounds like its coming from the front suspension underneath the car or something. Anybody else experience this in their s13?
Thanks!
Old Mar 28, 2005 | 08:05 PM
JDMxDrift's Avatar
ummm, i have something similar, but i think mines on the rotor. There is pauses between the sounds under light braking. Sounds like a warped spot on my rotors.
Old Mar 28, 2005 | 09:31 PM
RPS13Freak's Avatar
Yeah, I got that same problem when I brake hard. I changed my rotors to slotted rotors and new pads also, but it still squeeks when I brake hard.
Old Mar 28, 2005 | 10:18 PM
JDMxDrift's Avatar
Did you guys make sure to put the shims on the back of the pads?? Did you use brake quieter as well, i hear it works well...
Old Mar 28, 2005 | 11:11 PM
Levi SPL S14's Avatar
It could be your spring or the T/C rod.
Old Mar 29, 2005 | 09:13 AM
JVD's Avatar
JVD
I'm pretty sure it's your springs. My bros skyline does this. Does it make the sound when you go over bumps???
JVD.
Old Mar 29, 2005 | 09:42 AM
LaDyInRed's Avatar
well, after another day of driving and trying to listen for the creaking, it's NOT when I press harder on the brakes--i think it just creaks whenever I'm slowing down.. but it doesn't sound like its the brakes, cuz brakes usually have a higher-pitched squeal... maybe the springs or tc rods? i'll look into those possibilites.. could it be the front swaybar endlinks? lower control arms? i am still running on stock suspesion...
THANKS FOR YOUR HELP!
Old Mar 31, 2005 | 04:42 PM
JDMxDrift's Avatar
dang. i'm hearing the same creaking. If its springs it should be gone when i get my RM/A8's...
Alpha-Omega
Nov 14, 2007 11:31 AM
JDMxDrift
May 8, 2005 11:58 AM
Skyline
Jan 9, 2005 07:44 AM
brodie
Apr 28, 2003 07:38 PM
Silvia240
Jun 18, 2002 12:42 PM
