HELP GUYS S13/S14 rear brake fitment
Old Jun 8, 2004 | 09:38 PM
okay if you read my brake fluid story, you know I was losing brake fluid... now I know why - left rear caliper piston seal has a tear in it. I visited a couple junkyards looking for a replacement, but all I saw was three S13's and only one S14 (with the entire rear suspension taken already, including brakes)... can anyone tell me if S13 rear brake calipers will bolt onto an S14? I can't drive my car at all until I get this fixed and local shops want to charge me $400 to get both rear calipers replaced as a unit (they wont do seals, or only one side). So does anyone know if it'll work!?!?
Also, I'm like 99.9% sure on this, but there were no changes in rear brakes from 1995-1998, right? And does ABS/non ABS matter if you're just replacing the caliper?
Old Jun 9, 2004 | 01:54 AM
ahnyoungboi's Avatar
i have my rear brake set up still....including lines and all that....just hit me up i finished my inals tonight.....5 STRAIGHT HOURS~! 6-11PM
well yea....
hit me up on aim or something...ill be at school til friday...and then ill be in fullerton
Old Jun 10, 2004 | 10:02 PM
twistedriver's Avatar
I don't know if this will help. But is there a part # on the caliper it self? If yes you can compair the caliper # to see if they are the same. I search carparts.com for rear caliper without ABS for s13 and s14 and both car's caliper part # match. So If i am not wrong then both car's caliper should be the same. I hope this helps.
Old Jun 10, 2004 | 11:22 PM
LTSCUDRFT's Avatar
i could get you the part from nissan or aftermarket if you want to wait for it to be shiped,, it will be alot cheaper.... i see that you are in cali so it might take a week to get to you, but hey it would be worth wait to save lots of $$.
P.S. i know the rear aftermarket calipers for my s13 were $105 CDN tax inc. so the s14's shoulden't be much more. BUT that's if you want a new one (or two) my frind at nissan said that the caliper and bracket for the s13 were 150 or so (CDN) i'll check today on the s14's for you.
Old Jun 11, 2004 | 01:27 AM
it's ok I was saved by ahnyoungboi who had a pair of S14 rears just sitting in his trunk after an upgrade... $40 for both - not bad at all
Old Jun 11, 2004 | 10:04 AM
LTSCUDRFT's Avatar
good find
Old Jun 13, 2004 | 10:13 AM
hey....wat can i say...i gotta hook up the 240 community
positron
Oct 8, 2007 05:24 AM
Enlefo
Sep 8, 2007 06:41 PM
nissans13
Aug 23, 2006 02:54 PM
l2aine
Aug 28, 2005 02:28 PM
dkdeleon
Nov 14, 2002 11:33 AM
