I Got My Calipers!!!!
YAAAY the day has come to where I have my 300zx brake calipers!
the only problem is that I dont want to have to use the rotors that they came with, I would prefer to have some slotted rotors to go with them, do you know where i can order some?? The stock rotors are 26mm because they came off of a 1990 na 300zx
Originally posted by Krazyballa3
Hey you said you got ur calipers off of a 300zx NA ... do the Na and turbo have the same brakes.. i m guessing the 280 or 300 hp beast would have bigger brakes than the NA
AS you can see, for the most part they both use the same set up
Originally posted by -HyJynX-
Awesome
http://www.performancerotors.com/nis...e-rotors.shtml
^^Pretty good place to get rotors.
Originally posted by ChuckGoon
Question: does 300zx have 4 lugs that fits on 91 240sx?
1.) Pick up a set of the Z rotors (most likely ur doing the front).
2.) Take out ur front S13 rotors.
3.) Place the S13 rotors on top of the Z rotors (make sure the front faces of the hubs are on top one another.
4.) Line up the holes where the hub goes thru, and make sure the 4 lug pattern is on the metal surface of the Z rotors. Then with a spray can, CAREFULLY mark the 4 lug S13 lug pattern onto the Z rotor.
5.) Then u find a drill that is at least the same diameter size of the S13 studs and drill out the holes where u marked it with the spray paint.
It works, and I kno a lot of ppl who go this route to save ubber cash from pickin up 5 lug hubs and all. I'll ask my friend for pics of how the Z rotor will look like when its complete. It actually looks tight... until u put the rim back on, then u dun see it no more...
BigVinnie
Feb 17, 2008 07:52 AM
badman70_1
16
Mar 1, 2004 08:02 AM
three things:
