Lets get a final answer on Rear Camber....
Old May 25, 2005 | 10:32 AM
vbgambini's Avatar
Ok I really havent found a straight up answer on how to correct the rear camber on my 1995 240sx dropped on Tein Flex Coilovers? Is there any DIY like my old SI using a few washers? Or whats the best kit out there that is not too expensive? Im looking to get a rear camber kit, the fronts look fine.
Old May 25, 2005 | 01:57 PM
KeN VeRsUs RyU's Avatar
search : RUCA
adjustable rear upper camber arm. I got mine on ebay. easy install. Go to an alignment place that knows how to adjust it (i did mine at sears.. pretty simple). I got the same set up as u. Simple as that.
Old May 27, 2005 | 01:35 AM
Levi SPL S14's Avatar
damn cheap bastards.
Old May 31, 2005 | 06:18 PM
rkcarguy's Avatar
When you got your adj arms did you have an alignment done? Looking at the design it almost looks like you would need both upper arms (4) adjustable or you'd get a nasty toe angle that would eat tires. I just put $1800 worth of 18"s on my car and I'm going to correct the camber issue before I drive it and eat up $500 worth of tires in a few months. Sadly there is no way to add washers like honda, you must BUY or be able to fabricate. The stock rearend actually has a little adjustment via cam washers, but not much. If nothing else turn them all the way out.
Old May 31, 2005 | 10:05 PM
For an alignment, all you need is the rear upper camber arm. If anyone says you need the other arm for toe or a toe kit, go somewhere else quick! The stock arm is enough. RUCA is all you need.
Old Jun 1, 2005 | 01:18 AM
Ya RUCA then alingment then drive your car and be happy.
Old Jun 5, 2005 | 03:19 PM
RUCA. If you spend the $ on Flex, spend the money to use them right.
You don't need rear toe or traction rod upgrade even if you go 3.5" low. Trust me. I know.
LOL
Old Jun 5, 2005 | 05:03 PM
vbgambini's Avatar
Yea I know. Where can I get those at a good price? Easy Install? Is that all I need?
Old Jun 5, 2005 | 06:15 PM
CowboyTurbo's Avatar
u can find 'em on eBay...
jspaeth
Apr 2, 2006 10:01 PM
Ghettostamps
New England
Apr 18, 2005 03:48 PM
G2FAST
West Coast/Hawaii
Dec 13, 2004 10:08 PM
dunkee
Jun 11, 2004 12:27 PM
rudeboy
Feb 4, 2003 12:50 AM
