master cyliner bore
i am buying a wilwood pedal assembly( reverse mount triple master cylinder) and i have to choose my master cylinder bore. they have them sizing from 5/8 bore, 1.3 stoke all the way up to 1 1/8 bore, 1 ich stroke. ive heard that the bigger the bore the better because it gives you maximum clamping force. is this true? in this case, is bigger better?
btw in the class i will be in i must use stock calipers but have ss brake lines |
well, dont quote me on this, but the way i would see it in this case, bigger might not be better. sure it would give you better clamping force, but at the same time, with the small surface area of a stock caliper/rotor, that may give too much clamping force, which will cause you to lock up the brakes too fast when braking and cause your wheels to lose traction....so maybe the best route would be to check the FSM and see if it says what the stock bore/stroke is, and then maybe go a step or 2 up from there?
Re: master cyliner bore
Originally posted by projctSlipAngle i am buying a wilwood pedal assembly( reverse mount triple master cylinder) and i have to choose my master cylinder bore. they have them sizing from 5/8 bore, 1.3 stoke all the way up to 1 1/8 bore, 1 ich stroke. ive heard that the bigger the bore the better because it gives you maximum clamping force. is this true? in this case, is bigger better? btw in the class i will be in i must use stock calipers but have ss brake lines The combo of each MC used should total the same area of your current single IF you plan on using the same calipers you have now. If not, then the area requirements need to be based on the projected area of each end of the car with regard to piston area. And with no assist the larger bores will prove far more difficult to operate if you go too far. |
