Megan Racing vs Apexi N1 coilovers THE TRUTH NOW
Edit by Raine:
People pay attention: Apex-i and Megan coilovers are NOT the same. Please see the last post in this thread. BELOW IS THE ORIGINAL POST IN IT'S ENTIRETY (minus the photos): PROVEN FALSE: ================================================== === It's time to let the cat out of the bag... I have said the MR coilovers are resold by several brands, and rebadged by many of the JDM brands... I'll let you guys put 2 and 2 together... Apexi N1 coilovers: $1300 MR's: $900 Saving $400 on the same coilover: Priceless..... |
Hahaha priceless HAHAH!!!
Nice "made in Taiwan"... Woot Woot...:D
Trust me 80% of the Japanese parts are made in China/Taiwan/S.Korea... I can assure you...
^ I thought every on knew that.
The parts are sourced from china,taiwan,korea assembled in japan. Except the shock part that is usually made in japan for different companies. |
nice to see someone backing up what i said..
sticky for sure best value in suspention right now |
Catharsis, i thought the KTS were the best value in suspension right now?? no:dunno:
Originally posted by underground Trust me 80% of the Japanese parts are made in China/Taiwan/S.Korea... I can assure you... |
they were...
Originally posted by JDMxDrift So all the little pieces are manufactured by 6 yr. old kids in china then shipped to Japan for assembly, then shipped to america for a 1000% mark up?:eek: |
Re: Megan Racing vs Apexi N1 coilovers
Originally posted by underground [B]It's time to let the cat out of the bag... I have said the MR coilovers are resold by several brands, and rebadged by many of the JDM brands... I'll let you guys put 2 and 2 together... Apexi N1 coilovers: $2500 MR's: $900 Saving $1600 on the same coilover: Priceless..... |
uhh he megan racing coilovers say apexi n1 all over them
Originally posted by Catharsis uhh he megan racing coilovers say apexi n1 all over them In response to what I think you're asking, Megan denies the rumor which claims a connection between the Apexi ExV and the Megan Coilovers. |
where?
They do look alike but where you get the $2500 price I don't know. I found them for $1189. Here is a compersion of the specs
- Full Coil Over Threaded Base - Monotube Shock Absorber utilizing a 44mm diameter piston - 32 level damping adjustment - 62 mm direct wound spring - Piston diameter is 44mm - Front springs rate is 8k and rear springs rate is 6k - 22mm Strut type rod (All others use a 12.5 mm rod) - Quick Adjuster, Coil Over Adjustment Wrench included - Exclusive Upper Mounts - Aluminum Brackets (Strut utilizes steel brackets) - One Year Warranty for (Oil, Gas) Megan Racing - Spring Rates: 8kg Front and 6kg Rear - Pillow Ball Upper Mounts. - Rubber Dust Covers. - Adjustable Ride Height - Aggressive Spring Rates - Single-Cyliner Design - Aluminum Brackets 32 Levels of Adjustment: 1-8: Suggested for track use. 9-16: Suggested for mountain/aggressive use. 17-32: Suggested for common street use. - All coilover damper kits come with 1 year manufacture-defect warranty. Not bad for an entry level coil-over but at a $200 I might go withthe Apexis just becuase they are a trusted brand. heres a pic ofthe megans to compare http://www.streetrays.com/catalog/im...an_dampers.jpg |
