"need Help Cracked Subframe"
i need some advice right now i have a crack " huge crack on the subframe". the cracks on the seem. it is condemned unsafe to drive.
here's a pix hope you guys see it cause the pix is on from my cell http://i5.photobucket.com/albums/y15...1157391146.jpg |
With the effort involved to drop it and weld it (maybe this is just a stupid idea)....it might be just as easy to buy a new one or get one from a junkyard
if it was welded i dont know cause what if its cracked again. and theres no junkyard around here that has any s13 laying around. thats a problem.
pull one from the jyard like they said
looks like epoxy bonding glue. id weld. where is this crack?
a little to the left from the bottom bolt. the cracks is from the bottom through half way on the subframe.
it will only get worse with time.
if you can weld it and try to reinforce the whole subframe. you will feel a difference. that is if you cant find another one. |
No selling. This is not the forsale area.
You could have sent that to him in a PM. -Levi |
Originally posted by s13silvia123 if it was welded i dont know cause what if its cracked again. and theres no junkyard around here that has any s13 laying around. thats a problem. Back to subject, I'd replace the sucker. I've been in the autobody collision buisness for over 3 years, welding wont do jack for a cracked subframe (even compromises it) unless you do major reinforcement plating to that subframe. My best advice would be to go and search for a rear sub (sourcing one out from a Nissan junk yard, they can help you locate one relatively close to you) OR Find a JDM S14 or S15 (S15 if you can find one) and replace it with that. S15 rear subs are very stout and can take a good beating from drifting. If you want to swap out to a JDM sub, check out the Vendor for sale section here... I coulda sworn I saw one of them who sells a lot of rear end clips for reasonable price. It's all in the amount of effort you want to put into sourcing one out. Good luck!:thumb: |
