Need help here. tention rod bushings broken
my front tention rod bushings are broken since 2003. dealer wants $95 for each tention rod. no bushing for sale individually. guys any good suggestions?
Stay away from urethane bushings. They're known to break things....
I'm running whiteline bushings on OEM tension rods. Steering response improved a lot (just like with solid pillowball rods), is a lot better compared to the OEM jello, and it's less $ than going with full pillowball tension rods. And, like I stated above the slight "play" that the poly bushings have over a solid piece of metal helps absorb some road shock IMHO
Originally posted by l2aine
Pillowball tension rods are more known to break if driven on harsh roads compared to poly, because pillowballs have no give in them - they're super solid so there's no means to absorb road shock. They're stronger and more precise on the track, but aren't the best choice for a car driven on public roads.
OK so what is or outcome here. I have to make this decision soon. And need help deciding. Whiteline bushings or tein tension rods. I kinda need something ASAP and would rather save money for now and get the bushings. BUt if it's better to get the tension rods i'll wait til i can afford them.
Unless you're buying the bushings already installed make sure you get a quote for pressing them in before you decide. The local dealer near me wanted over $200 just to press in nismo bushings and a few other shops don't even have the right size drifts to do it.
Whiteline bushings are great for daily-driven cars.. stiffer than stock, better response than stock, but not so stiff that you feel every bump in the road.
Pillowball Tension Rods are stronger, even more responsive (especially when braking), but might be too harsh on daily driven roads. Since there's no 'give' in a solid pillowball, any bump you hit will be transmitted through the whole chassis.
And the stupid guy got something right - installation for the bushings could cost anywhere from $40 to $200 (although anyone dumb enough to spend $200 on bushing install would have been better off buying pillowball rods instead for the same total $)
