(Need Help) - Suspension Setup for Drifting
Old Sep 10, 2002 | 04:20 AM
billyher's Avatar
Thumbs up (Need Help) - Suspension Setup for Drifting
What is a good suspension setup for drifting? What I have now is just cheap KYB gas shocks and Eibach springs. I think 400 in the front and 300 in the rear. I have no clue how to make my 240 better at drifting.
Old Sep 10, 2002 | 08:35 AM
I'm with Stupid's Avatar
Go buy some anti-sway bars and a lsd, that should make a world of difference.
Old Sep 11, 2002 | 03:40 AM
billyher's Avatar
I was thinking about 300zx LSD, but not sure which anti-sway bar to get. Any suggestions on which LSD or anti-sway bars.
Old Sep 11, 2002 | 06:52 AM
Import Fanatix's Avatar
Well get a Suspension Techniques Sway Bat, they are well known through the indstry and have a great reputation and have heard very good things about them from users in the forum. WHiteline I also heard is very good, but I would go with the ST ways, IMO
Old Sep 11, 2002 | 08:41 AM
I hear that the Suspension Techniques sway bars have fitment problems sometimes though.
Old Sep 11, 2002 | 05:03 PM
StanBo's Avatar
Silviaspeed has the ST bars and says they are good.
I am going with the Whiteline. They are adjustable which gives me more options.
Old Sep 11, 2002 | 05:58 PM
S13drifter's Avatar
Try to get a LSD or should i say VLSD from a 240sx that came with VLSD. If you go with a VLSD from a 300zx you will need new output shafts they are going to cost $150 a peice so $300 + the 300zx differnetal. But most of us can't find a 240sx with VLSD and use the 300zx diff. CHeck this sight out
http://www.**********/links/installs/lsd2/index.htm
http://www.**********/links/installs/lsd/lsd.htm
That will help you out. Now about your suspension, the stiffer the better. If you have adjustable shocks put your rear on as stiff as you car and the front is preferance. I have them set alittle soft compard to the rear so in the drift i don't lose steering. Good luck.
ryan15
May 22, 2006 06:21 PM
Black240Coupe
Mar 25, 2005 04:40 PM
DrftDmn
Jun 26, 2003 10:46 AM
CRooKeDCoP
13
Mar 6, 2003 01:28 PM
Sizzzoooo
Mar 11, 2002 01:56 PM
