new breaks e-break light is this a problem??
I just put on some new rear rotors and brake pads.. now after since my e-break light has either been saying ON while the e-break is all the way down.. .or sometimes the e-break light will just flash once and say off for the rest of the day. what does this mean?
any help out there?
what the hell?!!! i know its a stupid ass question but please somone be nice and give me answer! is the e-break flashing a code or something? god damn i need help i dont wanna be drive with a e-break flashing. doesn't feel safe
No need to get agitated, obviousy someone hasn't encountered a problem like yours. Have you adjusted your e-brake?
okay sorry. no i have not adjusted the e-break. i dont know how to?
a 92 is a pretty old car. Maybe a worn or burnt out E-brake sensor? Maybe its the rear harness. I never ran into this yet.
check your fluid :thumb: it used to happen to me when it got cold because the fluid would leak out.
so how do i adjust my e-break cable?
there is a 10mm bolt under your e-brake cover (you do not have to remove the cover) just pull the E-brake up and look at the front/bottom of the cover and you'll see it, just tighten it or loosen it.
I agree with LTSCUDRFT , sounds like LOW Brake Fluid.
