Parking brake light
My parking brake light will not turn off. It started happening about two weeks ago. I can release the brake but for some reason the light will not go out. Has anyone else had this problem? I would like some insight before I tear apart my dash. Thanks.
check brake fluid
i am having this same problem and i did all the required things...brake fluid, brake pads, light sensor, power, ground all that mine in still on...its a pain in the ass!
yeah I checked all those too, but nothing came up. WTF
this happened to my sisters sentra. when u push in the brakes, there is a pin *most likely stuck) that pushes a button that allows the brake lights to go on...
just check to see that its not stuck |
gah!!! i forgot about that sensor in the back fo the pedal check that
still is functional... i hate that stupid light!
WTF I am having that same problem. But I think its coming from my Hand Brake. I disconnected the harness but the light was still on.....
I <3 240's |
thats the problem we are having...from the e-brake/ hand brake/ wee stick
you guys check the little metal contact under the center console, right? Or not?
i did...
i know this sounds simple, but check the button on the end of the handbrake it could be stuck or jammed
thats what mad eit start in the first place i think....i was trying to install my drift button and it stayed on after that
it never came on when i just pressed in the button before though im going to go play with it right now to see if i can get it to work. |
