s13 rear camber suggestions...
Old Mar 9, 2003 | 08:36 PM
Turboed240's Avatar
I just put my Tein HA's on and I got wicked camber in the rear...I cured the front using the pillow mounts but I need to know a reliable way to cure the rear...I dont have the loot to spend on control arms right now so I need another alternative for the time being. Any suggestions?
Old Mar 10, 2003 | 02:40 PM
Justin.b's Avatar
You can get the Whiteline rear eccentric bushings from www.pdm-racing.com . Or you can have your arms slotted. I'd go with the bushings.
-Justin
Old Mar 10, 2003 | 05:24 PM
StanBo's Avatar
How far did you go down on the bodies?
How many threads are left?
Old Mar 10, 2003 | 09:29 PM
Turboed240's Avatar
There is about 1/2 inch of threads left...its tuckin a LITTLE tire...I am gonna raise it up a bit though...its too damn low..lol
Old Mar 11, 2003 | 03:07 AM
StanBo's Avatar
So you are close to me. I have 7 threads left. I am tucking about a half inch of tire in the rear.
I am raising it a hair after I install the plates.
Did you get the rear plates as well? That would give you a bit of a lift.
Old Mar 11, 2003 | 05:49 AM
Turboed240's Avatar
I just ordered them...I think Im just gonna get the JIC arms...what the heck...its only money...
Old Mar 11, 2003 | 06:37 PM
StanBo's Avatar
Zactly. You can always work and get more of it.
Old Mar 11, 2003 | 06:47 PM
Justin.b's Avatar
I keep working just to catch up with the money I already spent.
-Justin
Old Mar 11, 2003 | 07:52 PM
Turboed240's Avatar
I hear that...damnit...now im having another problem. Lets see if ya got any suggestions on this one...Ive tried everything. I have no brights, no brake lights, and no reverse lights. I have checked all the fuses. They are all fine. Bulbs are fine. My brakes worked last night and boom...today, nothing. Im wondering if its a relay problem. Any ideas? If its a relay, where are the relays located at?
Old Mar 11, 2003 | 09:15 PM
Justin.b's Avatar
Is everything else working? Radio? Interior lights?
-Justin
Old Mar 12, 2003 | 02:58 AM
StanBo's Avatar
Did you check the fuses in the engine bay?
Old Mar 12, 2003 | 05:49 AM
Turboed240's Avatar
There are no fuses in the engine bay for the tailights, or reverse lights. The only things in the car not working are the reverse lights, the brake lights, and the brights. I know there is another fuse block buried under my intake...I didnt check anything in there? Is the culprit hid in there?
Old Mar 12, 2003 | 07:07 AM
Justin.b's Avatar
There are a bunch of fusible links in the relay box on the passenger side of the engine bay. You may want to take a look at those.
-Justin
jspaeth
Apr 2, 2006 10:01 PM
Carparthookup
Oct 6, 2005 05:51 PM
lrb_2000
Apr 10, 2005 03:21 PM
jackyliem
Dec 25, 2004 05:03 PM
Jonas
Jul 29, 2003 03:20 AM
