Stock Toe Settings
Okay, the car is an S14 1995, and on either side of the differential (when looking at the car from the rear) there are two bolts that are used to adjust the rear toe. Does anyone know what the maximum/minimum angles are when adjusting these bolts? I noticed my right side wasn't positioned in the same angle as the left, so I looked at the bolts and sure enough the bolt wasn't positioned the same (well, mirrored) as the other side.
Are you trying to eyeball your alignment????
Take it to a professional. He already has the OE specs... |
dont do oe thats boring you want this alignment
front: Camber: -2.5 to -3 deg caster: 8 deg toe: 0 deg rear camber: -2 deg toe: 0 deg |
Yeah, but you'll have to have adjustable height coilovers and camber plates on the front.... Not to mention adjustable t/c rods in the front....
okay I"ll repeat the important part of my post since it seems that everyone's answering something other than what I asked:
"Okay, the car is an S14 1995... Does anyone know what the maximum/minimum angles are when adjusting these bolts? " That's it. I never said anything about doing my own alignment or what specs I should run, etc. :p |
If you're not doing your own alignment, why do you need to know?
Number one MOD for EVERYONE buying a 240sx should be an FSM..... Unless you're just following the trend that you saw in all of the magazines.... And got your daddy to buy you a 240sx... And your daddy pays to have all that APC chit put on your car.... In that case, just ask daddy what your alignment tolerances are.... |
Originally posted by JeromeS13 If you're not doing your own alignment, why do you need to know? Number one MOD for EVERYONE buying a 240sx should be an FSM..... Unless you're just following the trend that you saw in all of the magazines.... And got your daddy to buy you a 240sx... And your daddy pays to have all that APC chit put on your car.... In that case, just ask daddy what your alignment tolerances are.... I do have an FSM and so far all I've found in it is recommended settings, not the actual range of adjustment. And I'm asking about min.max adjustments because I'd like to learn more about my car, so I won't make myself look like an ass by assuming that I know everything like other people do. :thumb: |
If you're wanting to know exact min/max, its going to vary car by car, since each cars' suspension wears differently...
Well I don't expect that my rear suspension will be at factory tolerances after being 9 years old, but I'm just wondering what range of adjustments are available with the factory toe (i.e. without resorting to aftermarket lower arms, etc.)
You can probably max it out at about 2 degrees camber and 2 degrees of toe with the factory setup....
