Tie Rod Boot Question
Old Oct 18, 2004 | 07:16 AM
Has anyone replaced their own tie rod boots? For those who are lost, it's the rubber covers on the inner end of the steering tie rod. I got a new pair but I'm iffy on the install because I don't want to mess up the alignment, don't know if I need any special tools, etc. I figured I could mark the tie rod adjustments so I could disassemble then reassemble back to how it was, but I'm not sure if that can actually be done. Your thoughts?
Old Oct 20, 2004 | 10:51 AM
TWAN's Avatar
yes it can be done. just be sure to mark the bolt to tie rod with two alignment marks. then mark the threaded side so that you can turn it back to the exact spot it was before the disassembly. when its back together it should line up. just be sure not to turn the threaded side. because then it will throw you off.
i just ended up locking a pair of vise grips on it and making sure it didnt move. but to answer your question, it can be done. and its fairly simple.
Old Oct 20, 2004 | 12:31 PM
cool thanks... now if I can only get away from the fun I'm having driving ni the rain
zeroGripS13
Oct 7, 2005 04:32 PM
RealDS13
May 24, 2005 04:53 PM
Hamsterball
Apr 12, 2005 10:23 AM
IAM-SO-sLOw
30
Jan 2, 2005 11:04 PM
poweredbysatan
Oct 28, 2004 05:32 AM
