Widest tire for 17x8 rims?
Old Sep 23, 2004 | 08:54 PM
240sxFan's Avatar
I've been looking to see if I can find any info to see what's the widest tire that'll work w/ 17x8 rims. I see wheel/tires packages with 205/45/17. Can I use anything wider? like 215? What's the widest I can get without the outer rim getting soft? thx!!!
Old Sep 23, 2004 | 08:58 PM
ArticDragon's Avatar
The usual max for 205s is 7 inches. 215s would be ok on the 8 inch rim, but it'll be slightly streched I think, not sure. Someone correct me on this. But don't run 205s, that's a little too narrow.
Old Sep 23, 2004 | 09:03 PM
240sxFan's Avatar
Oh.... Those are the tire width they come w/ the 17x8s. Ok. thx
Old Sep 23, 2004 | 09:47 PM
edubb11's Avatar
The widest that you can 'safely' mount on an 17x8" rim would be a 245. That is what I run on my WRX with no problems.
Old Sep 24, 2004 | 12:03 AM
205s fit well on 6.5" wheels...maybe even 6" wheels.
edub said it...245's is the widest I would go on a 8" wheel.
Old Sep 30, 2004 | 11:40 AM
Gnarly Dragon's Avatar
im rockin 225/45 on my 17x8s
Old Sep 30, 2004 | 08:24 PM
drew935's Avatar
I'll be getting 17X7 with 225/45 and 17X8 with 245/45
Old Oct 7, 2004 | 11:06 PM
sage's Avatar
doesnt have to do with ur 17inch rim, but i fit a 225/50/15 on 7in wide advan rsrr.....sticks out a bit, not optimal for sidewall stiffness, but it works and grips much better than the 205's i had before! one thing is, it rubs my tein he's if i dont adjust the stock camber adjuster to like 0degrees or so. thus, maxing out my camber plates only gives like 1.5 or 2 degrees camber, and i need more, especialy with these soft (kumho 711)sidewalls.
sage
BADA$$240
Apr 1, 2007 06:12 AM
dmora
34
Jan 3, 2005 11:25 PM
240slidekat
Dec 20, 2004 08:25 PM
kade4me
May 15, 2003 09:16 AM
mmbd
Apr 5, 2003 11:27 AM
