16psi on a ka24det
if i change the internals to forged pistons and rods, metal gaskets and low compression valve springs would i be able to boost in the 16-20 psi range. i am wanting a 320rwh 240sx. I also wanted to know if it is possible to twin charge it meaning sc and tc, like a root system.
A twin charger isnt very possible...since there isnt any SCs out there for the KA. But if you are willing to put together a SC...go for it. Your goal of 320rwhp is possible...but you just need to tune it very well.
primarily your bottom end (pistons, rods, etc). Your stock bottom end can't handle all that power on its own. You'll want to go with an aftermarket cam, and when you do that you might as well upgrade your valvetrain. Other than that, strengthwise, that's all I can think of. In order to acheive your goal, you'll have to do serious tuning and upgrading many other things, but as far as internals go, there's your answer.
Here's your B.S.
http://www.prism.gatech.edu/~gte227n/car.html
He's a local in ATL. Been running just like that for about 35k miles.
what doesn't make sense is that if that motor was so damn strong, don't you think someone else would have stumbled across that set up before? I mean, doesn't look like he put a whole hell of a lot of work into it, stock parts and just a "kit". He's got numbers to prove it.....I'm just confused on how he's the only one I now know of that is pushing 350 rwhp on stock internals.
I'm speachless...sorta. Time to do more research.
