Apexi AVCR on SR20det
Old Feb 22, 2003 | 09:53 PM
nismo92's Avatar
Question Apexi AVCR on SR20det
Has anyone with an sr20det used the apexi avcr to control there boost. If so how did you adjust your boost??? I know that if you turn off the setting it will go back to stock 7 psi. Any advice or suggestions will be a lot of help.
Thanks
Old Feb 24, 2003 | 03:40 AM
Monkey Force's Avatar
I guess Im not sure exactly wha tyour problem is... do you just wanna know how to actually set your boost? If so than than just scroll to the setting menu and it should be self-explanatory. If you've got your actuator and vacuum sensor hooked up, its pretty easy.
If you wanna use the scramble function you will need to buy some switch, i dont know how to do this.
Beckham23
Jan 18, 2006 07:20 AM
jic-life
Mar 15, 2005 01:20 PM
bztech
Nov 18, 2004 06:47 PM
srslider
Oct 20, 2004 06:08 AM
ahnyoungboi
May 18, 2004 02:27 AM
