Black intercoolers?
A light mist of flat black wont hurt but dont go overboard.
If anything you want to get it anodized, not painted. Do a google search on painted intercoolers( or intercooler painting). I have( along with quite a few others on many forums) covered this to no end.
With a search you will find all the info you need & then some.
how much would it cost to get it anodized? i dont really want people to see it, thats all. hide it a little. dont really like the look of seeing i through the front, makes it look like a grill at times. i would much rather have it black.
Here is a thought for you.. I'm sure you have seen the mesh grills that vendors sell for for hole openings( like for fog lights & such). Well most places like home depot sell that same stuff in bulk. Most of the time in MANY different colors. But mostly brown & BLACK.All it is, is the screen door protector.
Why not, instead of painting your intercooler, buy some of that & place it over the opening?
It is MUCH cheaper, you cant see it & you dont have to worry about the efficiency of your intercooler.
I have done it to MANY vehicles & it look squite trick.
You may want to give that a try first.
Just thought I would throw that out there for you.
Originally posted by Project Cheap13
No it doesnt.
You are dealing with fluid vs water.
Flow vs pressure.
They do not operate the same.
No it doesnt.
Flow vs pressure.
That makes absolutely no sense at all. Both radiators and intercoolers operate on the principle of heat transfer from hot masses (air or water) to cooler masses (outside air passing over rad/FMIC). Furthermore, flow versus pressure makes even less sense; both ICs and rads are under some pressure and have mass flow through them.
Painting the front of the IC with radiator paint will make no difference. In fact, it's better than regular spray paint because it's probably been engineered not to hinder heat transfer
im going to paint my greddy intercooler. there is a special paint(radiator/intercooler paint) my frined owns a shop and he just told me aobut this stuff. he said its like 12 bucks a can. big deal, 12 bucks. its all the same stuff.
