Bout to turbo would like to see your KA-T
1 Attachment(s)
I just wanna know how you guys are running your turbo setup on the KA. Where you are putting your MAFS, if the BOV is vented or recirc., what parts you are using, pics would be really sweet. I just wanna get an idea of how I wanna run, plus if anyone has the crazy manifold anything like I got I would love to see it. It is a side mount deal. I haven't seen many like it, exspecially for the KA.
hmmmmmmmmmm....you got me on the position of the maf. I would guess it would have to go between the ic and the tb since the car was non turbo. I wouldn't think you'd have to recirc, again because of it being a non turbo.
Someone enlighten me. |
Well I know a little about that. You can postion it prior to the turbo but then you would need to run a recirc BOV becuase once it releases the car will run real rick momentarily and try to stall. you could position it on the cold pipe (between IC and TB) and leave the BOV venting to the atmosphere. That is about all I know about that specific subject. If there is more enlighten me too.
a peek at my temporary setup ... more of a mock up, but it runs, and gives you an idea about how it will end up.
http://www.andrew.cmu.edu/~shersman/pics.html Romeyo you aint going to like the looks of it much, but dont knock me quite yet Steve |
are you going to use PVC piping as IC piping???? or just as a model?
its going to be metal soon
were you actually running the turbo with the pipes?
yeah, no problems.
runs beautifully |
you're ****tin' me....it worked with PVC? damn! Talk aboot a junkyard build......big ups on your creativity my friend.
haha that is awsome i am going to use that idea to make a model for the metal piping and take it to a machine shop like that but that is great what boost were you running on pvc???
talk about enginuity. nice job.:thumb:
thanks guys
Im running 7psi from a z31 turbo. its nice because I can change my setup and run different things without too much of a money crunch. its an extra 20 bucks to try a blow through MAF. easy to drill and get everything placed where I want it eventually. I just realized that i need to change where my FMU is plumbed, so Ill just drill a hole after the intercooler, and relace my plug. simple as that. its a lot of fun mocking up many different ideas. thats the best one that weve had so far with a draw through MAF. flexibility is key! |
i think i am going to do the 93 cobra with jwt ecu i am not too sure yet, money is deffinately the key.
inginuity at its best good idea for the mock up:thumb:
